Ajusting timings in AE CS5
Hey there
I’m a designer who has recently made the move from flash to AE for animation.
Love it! But I do have one particular challenge that keeps coming up.
In Flash, when I needed to extend or reduce the length of a animation, I could simply add or remove frames. I don’t think this is doable in aftereffects, and you must go into the composition, make your edits and then adjust it’s length on the timeline on which it rests.
From this point, I have the cumbersome task of manually moving all the other elements in that composition to accommodate the new timing.
I have a feeling there is a more sophisticated way to do all this 😉
If anyone can shed some light i’d be very grateful! thanks!!
Steve
