Activity Forums Web Design (WordPress, Joomla, etc.) AJAX to PHP return code.
  • AJAX to PHP return code.
    Posted by Lauren Brogan on November 21, 2012 at 3:14 am
    I’m just getting into coding with AJAX and am having a bit of trouble figuring out how to use AJAX code that returns content from a PHP file. I basically need it to pass in a page name and have the PHP load the contents of the page, then return to the client, then place in a DIV. Any help would be greatly appreciated.
    Demetri Tashie replied 13 years, 10 months ago 2 Members · 1 Reply
  • Demetri Tashie
    November 23, 2012 at 3:15 am
    if you work through these simple tutorials, you should get a good understanding of using AJAX to dynamically load contnet: https://www.w3schools.com/ajax/default.asp
    they go through step by step how to get your AJAX xml httprequests to work
