Activity › Forums › AJA Video Systems › Aja Xena SDI and HDLINK Pro to a plasma doesn’t work…
  • Aja Xena SDI and HDLINK Pro to a plasma doesn’t work…
    Posted by Gabriele Turchi on January 1, 2009 at 6:23 pm
    Guys does anyone have experience to use the Xena SDI and Blackmagic HDLInk Pro to connect a Plasma in HDMI?
    My Plasma(Panasonic 42PZ85U) works very beautifully (after Bob Zeli (thanks!!) suggestion) connected to the component out from Xena , but it does not accept any kind of signal from SDI—>HDLink Pro conversion…
    Is this because maybe the 85U accept only HDCP (copy protection) signal from the HDMI and the combination SDI—>HDLink Pro does not provide that?
    G
    Daniel Levy replied 17 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Tim Kolb
    January 1, 2009 at 6:48 pm
    What model are you using? The Hi5?
    TimK,
    Director, Consultant
    Kolb Productions,
  • Gabriele Turchi
    January 1, 2009 at 7:13 pm
    You mean what model of Xena?
    I have the LHe (actually is the Kone LHe…but using bootcamp and XP it became the Xena…)
    G
  • Tim Kolb
    January 1, 2009 at 8:00 pm
    …ah, I meant the adapter…but I spaced the “HD Link Pro” portion…it’s a Black Magic product.
    There is a mention on the site about a software upgrade for it to output to HDMI…is it possible that a software patch is needed?
    TimK,
    Kolb Productions,
  • Gabriele Turchi
    January 1, 2009 at 8:18 pm
    Thanks Tim,
    Where did you red that info?..i can’t find it..
    In the specs say oytput to DVI and HDMI display…
    Also the first time that i have connected the HDLink Pro using the USB cable i had a firmware upgrade…
    G
  • Tim Kolb
    January 1, 2009 at 8:30 pm
    It’s about halfway down on this page
    https://www.blackmagic-design.com/products/hdlink/
    by the yellow cable graphic on the right side…it may only apply to HD Link though, not the ‘Pro’…
    I’m not a BM user myself so I’m not sure of each model’s capabilities…
    TimK,
    Kolb Productions,
  • Gabriele Turchi
    January 1, 2009 at 8:43 pm
    i have just downloaded the very last one and relative firmware upgrade…still noting…
    G
  • Tim Kolb
    January 2, 2009 at 3:11 am
    I think at this point that it’s an HD Link problem either way…which probably makes it more productive to ask about this issue on the Black Magic Forum…wouldn’t you think so?
    The AJA equipment you have appears to be working fine.
    TimK,
    Kolb Productions,
  • Daniel Levy
    August 19, 2009 at 3:21 am
    Tim,
    I need to monitor SDI output from my Xena LH (for final color match, etc.) Would you recommend the AJA Hi5 that you mentioned above for an HDMI output to a HDTV, or the AJA HDP2 for a DVI-D output to a standard PC monitor?
    Additionally, what monitor/TV would you recommend? Can’t afford to break the bank on $2-4K professional monitors…
    Daniel
