Activity Forums Apple Final Cut Pro Legacy AJA RGB Levels issue between Color and FCP
  • AJA RGB Levels issue between Color and FCP
    Posted by Anonymous on January 9, 2008 at 1:07 pm
    Hi All,
    Okay – who want to have a stab at answering this….
    System:
    8-core MACPRO
    OSX 10.4.11
    7GB RAM
    X-1900 Graphics Card
    AJA KONA 3
    Ver 5 KONA drivers
    FCP 6.0.2
    Color 1.0.2
    SAN attached
    External Scopes via HD-SDI
    External 1920×1080 Monitor via Analogue RGB
    Got a HDCAM SR RGB 4:4:4 1080 23.98 project that has been edited in FCP.
    The Project was sent to Color and graded, then rendered out using the AJA KONA 10bit CODEC.
    Upon sending back to FCP, the files appear in a new timeline as usual, no problems what so ever.
    Then, you glance over at the hardware scopes…the blacks are crushed. Press play then the blacks are lifted to around 5% and the whites are pinched from 100% down to about 90%.
    If as a test, you then export a quicktime from the graded media from the FCP timeline, then import that into Color and drop it on a layer above in the grading project there is no difference in the scopes display – the blacks and whites are back where they should be….
    So the problem is that I cannot get the graded media to play back from FCP out of the Kona and look the same as it does in Color.
    Things I’ve tried:
    Known issues with KONA 3 drivers version 4 with RGB – when “AJA Kona3: 1080psf 23.98 10 Bit RGB” was selected the KONA would switch to YUV processing and NOT RGB – upgraded to version 5 – media now plays back and KONA switches to RGB correctly
    Adjusting the RGB ranges in FCP to full range from SMPTE in the sequence settings – makes things worse!
    Forcing the KONA LUT into LINEAR – this raises the black levels and does nothing to help the whites…
    Question:
    Does color render out quicktimes using the AJA KONA RGB codec at 0-1023 FULL RANGE even though in FCP the KONA as standard digitises the media and displays it in the sequence by default using the 64-940 range?
    Anyone had these sorts of issues?? Unless I’m missing something this means I cannot get a picture out of FCP and down to say HDCAM SR without looking different from the grade in color. I don’t want to be compensating in FCP!!
    Martin B. wehding replied 18 years, 6 months ago 4 Members · 3 Replies
  • Oliver Peters
    January 9, 2008 at 1:23 pm
    Not sure about why, but try this. Bring your Color media back into FCP but don’t do anything that requires additional rendering in FCP. Export a QT reference. Open that file in Kona TV or VTR Xchange. These are separate AJA utilities that address the card directly. Output to tape and see if you get acceptable results. One caveat, though. My experience with these apps is the output may not be frame-accurate at the exact edit in-point.
    Sincerely,
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Jeremy Garchow
    January 9, 2008 at 4:30 pm
    THis is probably the wrong answer, but have you turned of your range check? control-z.
    Jeremy
  • Martin B. wehding
    February 19, 2008 at 10:37 pm
    hi creative_tech
    Have you solved the problem?
    I have the exact same problem in FCP (I have’nt been in color yet). I’ve talked to AJA’s support about it but we have’nt been able to nail the problem.
    I’ve done a lot of testing with smpte, full range.
    The wierdest thing is that some clips play right, but others don’t.
    there seems to be some issues with QT : https://www.fxguide.com/article462.html
    All the VFX work we are doing on the film, we HAVE to do in After FX 8 (read the article) because all other comp programs crush blacks and clip whites.
    I’m not sure if this “bug” in QT have something to do with our problem?!
    reg
    Martin
    Martin Wehding
    Postproduction manager
    Fridthjof Film A/S
    Copenhagen
    Denmark
