Activity › Forums › AJA Video Systems › AJA – please review results on Dell 2405FPW with AJA HDP
  • AJA – please review results on Dell 2405FPW with AJA HDP
    Posted by Bob Zelin on May 15, 2005 at 6:11 pm
    I know you have one – how does it work.
    This makes it the cheapest 24″ LCD for Kona 2 HD work .
    Please let us know.
    Bob Zelin
    Walter Biscardi replied 21 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • John Abt
    May 15, 2005 at 8:54 pm
    Bob – the Dell 2405FPW works great with the HDP in both HD and SD. It will not do 50 or 48Hz though, so the HDP will frame rate convert to 60Hz for this display. This monitor also has HD/SD component video inputs – so Kona 2 can drive it directly with its component outputs. For 24Hz, Kona 2 will frame rate convert the outputs to 59.94 Hz if you change the “video playback” setting in the “Audio/Video settings” or “View” menus.
    (By the way, you can also downconvert 23.98 HD to SD by changing the “video playback” the same way).
    John Abt
    AJA
  • Walter Biscardi
    May 15, 2005 at 10:37 pm
    Bob, have you compared that Dell to the Sony MFM-HT75W? It has DVI, RGB, Component, Composite, and S-Video inputs. 720p and 1080i supported. I picked up one for $599 at Fry’s Electronics and I have to tell you, it’s stunning. Just curious if you’ve seen one of these and how it compares to the Dell.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Bob Zelin
    May 15, 2005 at 11:34 pm
    I have not seen the Sony MFM – I have only used the Cinema 23″ and the Sony
    SDM-P234b, of which the Sony is superior. But obviously, the Dell, at $1200
    has everyone quite curious, and I certainly am interested in seeing the Sony MFM. Now, from John’s report, I will certainly order a Dell 24″
    Between the insanely cheap monitors becoming available for HD, and the ongoing DAILY advances with SATA technology, the “last horizon” for the expensive edit room will remain with the VTR selection.
    I can only hope that AJA goes the next mile, and comes out with the “cheapo”
    Tri Level Sync generator. $1100 would be a nice price.
    Bob Zelin
  • Jeff Bernstein
    May 16, 2005 at 4:55 am
    Don’t forget the hardware waveform monitor as part of that.
    Jeff Bernstein
    Digital Desktop Consulting
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
  • Marco Solorio
    May 17, 2005 at 2:49 am
    [walter biscardi] “Bob, have you compared that Dell to the Sony MFM-HT75W? It has DVI, RGB, Component, Composite, and S-Video inputs. 720p and 1080i supported.”
    But its native resolution only goes up to 720p. Any 1080 material will get down-rezed. I think if you’re going into an LCD route, the Dell 2405FPW is a great way to do it.
    Marco Solorio  |   OneRiver Media
  • Ned Soltz
    May 17, 2005 at 3:40 am
    Check out the various deals from the aggregator sites such as dealmac.com. I have seen the Dell 2405 for as little as $1K from Dell with the correct “coupon code.” The only negative reports that I have heard (and I can’t point to them specifically at the moment) is that some users have reported units with stuck pixels. Once you can wade through the off-shore tech support of Dell, they will replace defective units quickly. The secret with dealing with Bangalore, I have found, is once the conversation begins to deteriorate, simply ask for a supervisor in Austin.
    Ned Soltz
  • Walter Biscardi
    May 19, 2005 at 10:11 am
    [Marco Solorio] “But its native resolution only goes up to 720p. Any 1080 material will get down-rezed. I think if you’re going into an LCD route, the Dell 2405FPW is a great way to do it.”
    We’ve run 1080 on it and it’s absolutely gorgeous. In fact, one of my VAR’s was here one day working with some 1080i footage he shot with the Panasonic camera (not sure which model #, it’s the one that only shoots 1080i) and he was amazed at the quality of the output.
    Not doubting that the Dell may be better, but the Sony is definitely worth a look. We’re going to use it as our playback monitor this weekend during our film shoot. I’ll let you know how that goes.
