Activity › Forums › AJA Video Systems › AJA Kona TV & Targa Sequences
Posted by Jeremy Garchow on May 30, 2007 at 7:46 pmI just got a major load of tga sequence files from some 3d dudes. Is there a way I can play these sequences out through KonaTV? Do I have to render out a QT first? Will the DPX translator help me here or do I need to use QT?
I have never worked with image sequences before so I’m a little newbile here.
Jeremy
Jeremy Garchow replied 19 years, 4 months ago 3 Members · 7 Replies -
Gary Adcock
May 30, 2007 at 8:15 pm[JeremyG] “I just got a major load of tga sequence files from some 3d dudes. Is there a way I can play these sequences out through KonaTV? Do I have to render out a QT first? Will the DPX translator help me here or do I need to use QT”
I would use the Seq > Make movie setting in QTPro – But make a REF movie using the aja codec and it will playout via Kona TV. Just make sure that your stills are on a drive fast enough to play back the files in realtime ( about 300G a minute)
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Jeremy Garchow
May 30, 2007 at 8:29 pm[gary adcock] “I would use the Seq > Make movie setting in QTPro”
Do you mean the Export > Movie to Quicktime function?
David Roth weiss
May 30, 2007 at 10:25 pmJeremy,
Why are you not just importing them into FCP and playing on the timeline?
David
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
Jeremy Garchow
May 30, 2007 at 10:30 pmThey are a funky size at the moment, and I was just trying to get a sense of the movement. Qt has done the trick. I have to recomposite them @ 1920×1080 later.
Since QT can open image sequence, I figured Kona TV can.
Jeremy
Gary Adcock
May 31, 2007 at 1:02 am[JeremyG] “Do you mean the Export > Movie to Quicktime function?”
In Quicktime PRO 7.1.6
from the File Menu
> Open Image Seg,
> set the desired frame rate
> then export a QT ref movie.gary adcock
Studio37
David Roth weiss
May 31, 2007 at 1:49 amSo they don’t have an alpha channel???
David Roth Weiss
Los Angeles
