Activity › Forums › AJA Video Systems › AJA KONA LS gives B&W output to monitor…
Posted by Harcharan Singh on July 11, 2007 at 4:14 amHi,
I am using a AJA Kona LS with BOB with Final Cut Studio 5.1.My problem is that the Kona Card is giving B&W output to TV monitor.
I have changed the source type to PAL from AJA control panel.
But no result.What can be the problem?
Thanks in advance.
HarcharanBob Zelin replied 19 years, 2 months ago 4 Members · 4 Replies -
Walter Biscardi
July 11, 2007 at 8:57 amSounds like the component cables are not connected correctly. Or you’re not set up correctly for the video you’re outputting.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Harcharan Singh
July 11, 2007 at 10:03 amHi,
Thanks for your fast reply.Even the composite out from the card is black and white.What may be the problem?
Thks
Harchu -
Gary Adcock
July 11, 2007 at 12:42 pm[Harcharan] “Even the composite out from the card is black and white.What may be the problem?”
You did set the control panel to Composite?
You should be using the y/g component connection for the Composite out.
what driver, OS and FCP are you using?
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Bob Zelin
July 11, 2007 at 8:59 pmcomposite and Y are shared outputs. You will get a B+W signal (no color burst) from the Y output. If you go into the Kona Control Panel ANALOG tab, you can change this to COMPOSITE, and you will get a color signal.
Before you test this with FCP, go to the CONTROL TAB in the Kona Control PAnel, and select TEST PATTERN, and bring up bars – send this bar signal into your TV, and have the analog out tab set to COMPOSITE. If it’s still B+W – it’s your TV that is not working.
Bob Zelin
