Activity › Forums › AJA Video Systems › Aja Kona LH and old PCI bus
  • Aja Kona LH and old PCI bus
    Posted by Nicola Di pietro on October 9, 2007 at 4:05 pm
    Hello!
    I have a doubt:
    I found an AJA document (PDF) with a diagram in which I read that the Kona LH “installs in PCI slot G4 or G5”. I saw that the PCI connector is divided in the point of the older PCI 32 bit slots, so the card is mechanically compatible with this kind of slots.
    So, since the AJA document does not specify in which model of PowerMac G4 the Kona LH can be installed, I can’t understand if will this card work in an older 32 bic PCI slot, because there are some G4 models with only PCI 32 bit slots, and other models with 64 bit 66 MHz PCI slots.
    This is my need:
    With a new Mac Pro PCI-Express I need to install the PCI-X Kona LH card, instead of buy a new LHe only for a bus issue!
    So I found these PCI-Express to PCI adapters:
    https://www.virtuavia.eu/shop/pci-express-to-pci-adapter-p29855.html
    https://cooldrives.stores.yahoo.net/1popcto4xpci.html
    but these have the 32 bit PCI slots, and I should fit the Kona LH card in it!
    Can anyone help me? or at least tell me which model of G4 is compatible with the Kona LH card?
    Thank you!
    Gary Adcock replied 18 years, 11 months ago 6 Members · 6 Replies
  • Alan Okey
    October 10, 2007 at 12:55 am
    You must have misread the diagram – the Kona LH is only compatible with the Power Mac G5, not with the G4.
    The Kona LH is a PCI-X card. It only works in G5s that have PCI-X slots.
    The Kona LHe is a PCI Express card. It only works in newer G5s that have PCI Express slots and in Mac Pros.
    Neither model works in the Power Mac G4.
  • Bob Zelin
    October 10, 2007 at 1:21 am
    Hi Mr. Drywood –
    I have never heard of anyone ever having any success putting PCI cards into a PCI-Express machine via a “bridge” – but if you get it to work – PLEASE let us know, because you will be the first ! This applies to storage host cards as well as AJA and Blackmagic cards.
    Bob Zelin
  • David Roth weiss
    October 10, 2007 at 2:02 am
    Don’t count on this working. Probably a good idea to bite the bullet. Sell your Kona LH on Ebay and buy an LHe.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Nicola Di pietro
    October 15, 2007 at 11:51 pm
    Ok, thanks to you all.
    If we’ll make this test, I’ll write you the result.
  • Javier Calderon
    November 4, 2007 at 2:33 am
    Would the Kona 3 work with PCI-X? I have a dual 2Gig G5 that I got in 2005. If not, is there extra gear that I would need to get to “adapt” my G5 to accept the Kona 3?
  • Gary Adcock
    November 4, 2007 at 3:27 pm
    [JavierC] “Would the Kona 3 work with PCI-X?”
    there are 2 versions of the Kona 3 card, one is PCI-e and one is PCI-x
    the cards however cannot be interchanged.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
