Activity Forums Apple Final Cut Pro Legacy AJA Kona drivers for FCP 7 are up
  • Aaron Neitz
    July 29, 2009 at 2:34 am
    The fastest hardware guys in the business.
  • Vince Sanchez
    July 29, 2009 at 2:59 am
    On my Kona Lhi I tried to play some 720p proxy files using the Kona easy setup for Pro Res proxy and got no output. When I set the video playback setting to 720p 8 bit, everything was fine. I tried this with the same P2 files transcoded to ProRes LT and had the same problem with the AJA easy setup. Don’t know if its my system or its a real bug, but if you have this problem, this is my fix. 1080i presets work just fine, so do all the fcp 6 projects I’ve tried 720 and 1080i.
    Vince Sanchez
    Intel Quad Mac 2.66
    AJA LHe
    HD link
    OSX 10.4.11
    FCP Studio 2
  • Bruce Jacobs
    July 29, 2009 at 6:39 am
    Read the notes about the ability to output to tape with insertion of an SCC file. For us, thus is huge: finally, we can avoid the hassle of a separate real time tape to tape captioning session.
