Activity › Forums › AJA Video Systems › AJA Kona capture setting for HVX-200 footage captured at 1080i 24P ?
  • AJA Kona capture setting for HVX-200 footage captured at 1080i 24P ?
    Posted by Pierre on September 13, 2006 at 4:59 pm
    Can’t find the setting. Footage was captured at 1080i 24p on an HVX. Not advanced.
    What should capture settings and sequence settings be?
    thank you,
    Michael
    Jeremy Garchow replied 20 years ago 2 Members · 3 Replies
  • Jeremy Garchow
    September 13, 2006 at 6:10 pm
    If you have removed the pulldown, setup a 1080i DVCPRO HD sequence, then hit apple 0 and change the frame rate to 23.98. If you have not removed the pulldown, then use the normal 1080i DVCPRO HD sequence @ 29.97
    jeremy
  • Pierre
    September 13, 2006 at 6:18 pm
    Great. Thank you.
    Unfortunately the footage wasn’t shot at 1080i 24P “A” (advanced) – so I don’t know how to get the footage 23.98. Do I have to run it through cinema tools?
  • Jeremy Garchow
    September 13, 2006 at 10:13 pm
    See my response in the p2 forum.
    Jeremy
