Activity › Forums › AJA Video Systems › AJA Kona 3 downconvertion
Posted by Yiannis Valkan on September 21, 2010 at 10:51 amHi all,
I would like to know if AJA KONA 3 can downconvert realtime from 1080i or 1080p to SD.
For eg. to import to AJA HD and output SD.Is that possible?
Mark Spano replied 16 years ago 3 Members · 3 Replies -
Gary Adcock
September 21, 2010 at 10:58 am[Yiannis Valkan] ” would like to know if AJA KONA 3 can downconvert realtime from 1080i or 1080p to SD.
For eg. to import to AJA HD and output SD.”Not from 1080 True P sources ( Red)
Use the 1080i or PSF settings and the downconversion will work fine.
gary adcock
Studio37Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, ILhttps://blogs.creativecow.net/24640
Yiannis Valkan
September 21, 2010 at 11:00 amhi and thanks for that quick answer.
The source will be an HDCAM SR video player.
So i guess that is fine?Thanks!
2 minds are better than one.
Mark Spano
September 21, 2010 at 7:21 pmI would like to add that if the SR tape is 1080i, the SR has a built-in downconvert, which you can choose letterbox, edge-crop, or anamorphic. And if your SR has the format converter option card installed, you can also add pulldown and downconvert 1080p SR tapes.
