  • Posted by Matt Rinaldo on December 17, 2008 at 9:37 pm
    I have a a AJA IO 101351. What I can’t find is my kona card. Where are Kona cards in the aja box or in the tower of the computer. I’m trying to learn this set up at work any resources that I should know about
    Shane Ross replied 17 years, 9 months ago 2 Members · 3 Replies
  • Shane Ross
    December 17, 2008 at 9:54 pm
    The IO doesn’t have a card. If it is the origial IO it connects to your computer via Firewire 400. If it is the IOHD then it connects via firewire 800.
    The KONA line is a card that you install in the computer.
    Shane
  • Matt Rinaldo
    December 17, 2008 at 10:06 pm
    thanks. this system was set up before I started working here. Im have trouble capturing i found a AJA Kona 2 firmware updater and it is saying that I I can upgrade the firmware, should I do that?
  • Shane Ross
    December 17, 2008 at 10:14 pm
    The AJA Kona firmware has nothing to do with the IO.
    Call AJA Tech support. They will help you figure this out.
    Shane
