Activity › Forums › Apple Final Cut Pro Legacy › Aja Ki Pro Files best organization in FCP
  • Aja Ki Pro Files best organization in FCP
    Posted by Craig Alan on January 16, 2011 at 3:32 pm
    I’m editing using Ki Pro ProRes 422 files. I first copied the files from the Ki Pro hard drive to my media drive. On my media drive, I created a folder in the Final Cut Documents folder called AJA. But I was wondering if they should instead be in the project folder in the Capture Scratch folder. Or somewhere else? In FCP, I simply imported them and they appeared in the browser. But as these files multiply I was wondering if this filing system will bite me.
    OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz
    ; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP certified; write professionally for a variety of media; teach video production in L.A.
    Craig Alan replied 15 years, 8 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    January 16, 2011 at 4:30 pm
    It really matters on how you archive. For each project, I have a folder that stores all my media for that project. I put KiPro captures in there as that entire folder gets archived, usually. My capture scratch folder doesn’t get archived all the time.
    Its really up to you.
  • Craig Alan
    January 16, 2011 at 7:43 pm
    Thanks Jeremy,
    In my render folder, each project has its own folder.
    In my Capture Scratch, each project has its own folder.
    Same with audio render folder.
    I also have a QT export folder.
    If I want to organize this by project in order to archive, can I just create a project folder move all parts of the project in there and then, if and when I need this media again, point FC to the files as needed?
    In the past, I’ve just copied the fcp media folders to a new hard drive, wiped my raid clean and started again using FC default file set up. But Pro Res files are much larger than what I’ve used in the past and this system might get messy sooner than later.
  • Jeremy Garchow
    January 16, 2011 at 9:16 pm
    There’s no right or wrong way as long as everything is organized and you don’t mistakenly throw away what you need. The method i use may not be the method you use.
    You should keep render files separaete from media files. That way if you trash your renders, you won’t confuse your render files and media files.
    Your method seems just fine.
    You can also use the free Preference Manager to Keep track of different prefs per project. This way every time you open a particular project, all the files will go where you want.
    https://www.digitalrebellion.com/prefman/
    Jeremy
  • Craig Alan
    January 16, 2011 at 11:23 pm
    Thanks. The KiPro import was new for me so I just wanted to make sure. I got an error message after one import that said the file was optimized for FCP. Get info said it was a ProRes 422 file so I just deleted it and reimported it and did not get any more error messages.
