Activity Forums AJA Video Systems AJA IOLA with Avid Xpress Pro??
  • AJA IOLA with Avid Xpress Pro??
    Posted by Jason Boucher on May 19, 2006 at 5:47 pm
    Looking to add Xpress Pro to my home system, which current runs FCStudio. I’m wondering if the AJA IOla I have will work with Avid. I see that it is basically designed with FCP in mind, but it basically does the same function of the Mojo. Doesn’t it?
    I’m hoping I can use tat for any non-firewire imports/exports…. Any ideas?
    Jason
    Jason Boucher replied 20 years, 4 months ago 3 Members · 3 Replies
  • Bob Zelin
    May 19, 2006 at 10:21 pm
    NO NO NO NO NO NO NO NO NO
    let me repeat
    it will not work, it never did work, it will never work, anyone that tells you it will work is in dreamland.
    So how do you get your AVID Xpress Pro to work with normal VTR’s ?
    AVID Mojo, and AVID Mojo SDI. Any other I/O solution ?
    NO NO NO NO NO NO
    ok?
    bob Zelin
  • Nick Price
    May 22, 2006 at 3:06 pm
    Hi Jason,
    the whole problem and limitation of the digidesign software line, is that they only with with digidesign hardware. THe only exception to this is the M-Audio box for Protools M-Powered. Other than that you have to buy expensive and limiting hardware….
    The beauty of FCP is you can get any number of cards/devices that work seemlessly with it. You can of course just digitise using firewire in Avid, but you wont be able to control any deck unless it has firewire, and you cant digitise in any codec other than DV, with (Xpress Dv).
    sorry about that
    nick
  • Jason Boucher
    May 31, 2006 at 5:18 pm
    Man, that’s a bummer.
    You’d think that with Avid releasing their software only versions, that they’d be more flexible with their I/O options.
    Hmmm…
    Anyone know of any good deals on a Mojo? How about this shot in the dark question…. would the Mojo work with FCP?
    I’m thinking no, but thought I’d toss it out there!!
    Thanks, you saved me (or cost me more, depending how you look at it!)
    Jason
