Activity Forums Adobe Premiere Pro AJA IO XT on an iMac
  • AJA IO XT on an iMac
    Posted by Per Ottesen on May 27, 2013 at 8:09 pm
    We’ve been connection an AJA IO XT to an iMac, and have set the System setting/Audio, AJA’s Control panel and Premiere Pro’s Preference panel to use the IO XT box, and it all works fine with audio in/out.
    The problem is, that suddenly the iMac use the internal loudspeakers instead, and when checking the settings, nothing has changed, they are all still set to use the IO XT as when it all works.
    We’ve tried to delete Premiere Pro’s pref file, but that didn’t help,
    Anyone with suggestions ?
    Per Ottesen
    Walter Biscardi replied 13 years, 3 months ago 2 Members · 3 Replies
