Activity Forums Apple Final Cut Pro Legacy AJA Io HD Timecode Break
  • AJA Io HD Timecode Break
    Posted by Jason Cox on April 1, 2008 at 2:35 pm
    I am having great difficulties capturing using the AJA Io HD in FCP. Everything appears to be processing normally and then when I batch capture or capture now I get an error that states that there is a timecode break. I have switched tapes and no matter what I try to capture I get the same error. Please advise.
    Russell Lasson replied 18 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Gary Adcock
    April 1, 2008 at 3:15 pm
    [MSHA DVD] “I am having great difficulties capturing using the AJA Io HD in FCP”
    more info would help…
    what are you capturing, how, OS and Software versions,
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Russell Lasson
    April 1, 2008 at 3:54 pm
    In general I’ve noticed that when I’m digitizing a tape and I’m getting “timecode breaks” when there really are no breaks on the tape, it’s because the device control isn’t set up properly to match the deck.
    Just because you might be able to control the deck doesn’t mean that you have a good device control setup for the deck. Try playing around with different settings by creating new settings in the Audio/Video Settings menu.
    As Gary said, more specifics would be very helpful.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Jason Cox
    April 1, 2008 at 5:22 pm
    OS 10.5.2, FCP 6.0.2, MacPro, 8 Core 3.2 GHz, G-RAID 500 External HD:
    Running Panasonic AJ-SD930 DVC PRO 50 Deck via RS-422 to AJA Io HD. All was briefly functioning properly but now is back to timecode break error. I am not sure what the problem is.
    Sequence Preset: AJAIoHD: 525 29.97 8 Bit
    Capture Preset: AJAIoHD: 525 29.97 8 Bit
    Device Control Preset: AJAIoHD: NTSC Sony VTR
    Note: Changing VTR presets does not seam to make a difference.
  • Russell Lasson
    April 1, 2008 at 5:43 pm
    Did you try creating a device control to be a Panasonic protocol instead of a Sony?
    We have a DV50 deck that doesn’t function properly on edit to tape unless it is set to a Panasonic setting.
    -Russ
    Russell Lasson
    Provo, UT
  • Jeremy Garchow
    April 1, 2008 at 6:10 pm
    and also do you have your ioHD and GRaid on separate firewire busses?
    Jeremy
  • Gary Adcock
    April 1, 2008 at 6:30 pm
    [MSHA DVD] “OS 10.5.2, FCP 6.0.2, MacPro, 8 Core 3.2 GHz, G-RAID 500 External HD: “
    how are you connecting the IoHD and the Graid at the same time???
    NO OTHER DEVICES CAN BE ON THE FW Buss, and if you did not add a FW card to your desktop you did this to yourself.
    gary adcock
    Studio37
  • Russell Lasson
    April 1, 2008 at 7:09 pm
    Jeremy brings up a great point! Often FCP says that there are timecode breaks when your drives aren’t keeping up. I’ve seen that before too.
    -Russ
    Russell Lasson
    Provo, UT
