Activity Forums AJA Video Systems AJA IO HD Support with new FCP Studio
  • AJA IO HD Support with new FCP Studio
    Posted by Shaun Gish on July 30, 2009 at 5:40 pm
    Anyone know if upgrading to the new FCP studio will mess up output with an IOHD? I have a multicam project I’d like to work on with the new marker system but I don’t want to upgrade and kill my output on my main tower.
    I realize that I probably won’t have support for any of the new prores codecs (proxy would be nice…) but that’s ok because I’m just using standard prores422
    Also – on a side note – I purchased my IOHD about a month and a half ago and it’s been really squirrely. I get green flashing frames on playback a lot of times and I also seem to have to render a ton (I’m just using the Easy Setup for AJA IoHD- 1080i 29.97 Apple ProRes 422 and my sequence is set to the AJA IoHD: 1080i 29.97 Apple ProRes 422 setting and all of my footage is captured as ProRes). I’m running a 2×2.26 Quad Core Nehaliem with 16 GB of ram and I have a 3.5 terabyte interal Raid 0 – I would assume that I’d be able to playback everything without rendering, especially since the IoHD handles a lot of the prores playout itself… several of my sequences have 6+ tracks of audio – any chance that’s the issue? If so – what’s the best way to handle that?
    Gary Adcock replied 17 years, 1 month ago 3 Members · 4 Replies
  • Jeremy Garchow
    July 30, 2009 at 8:03 pm
    [Shaun Gish] “I have a multicam project I’d like to work on with the new marker system but I don’t want to upgrade and kill my output on my main tower.
    AJA recommends sticking to FCS2 until they release official drivers/firmware updates.
    Hvae you talked to AJA about your ioHD problem? I assume you have the latest firmware and software updates?
    Jeremy
  • Gary Adcock
    July 31, 2009 at 1:14 pm
    [Jeremy Garchow] ” I assume you have the latest firmware and software “
    MY guess is that they have NOT updated to FCP 6.06. since that was a specific fix for this issue with the new 8 core machines.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Check out
    https://www.aja.com/kiprotour/
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Shaun Gish
    July 31, 2009 at 1:25 pm
    I did speak with Aja and I did upgrade my firmware… didn’t realize I had missed an update.
    Things are generally more stable and the real time performance is much much better… but I’m still getting some wonkyness – I’ve had a couple kernel crashes and the IoHD has frozen up a few times. I’m starting to wonder if it’s an issue with the actual box I have. I’m still talking to AJA… I’ll let you know what they say.
    Thanks for the help
  • Gary Adcock
    July 31, 2009 at 2:56 pm
    [Shaun Gish] “but I’m still getting some wonkyness – I’ve had a couple kernel crashes and the IoHD has frozen up a few times.”
    re-run the firmware updater on the IoHD.
    gary adcock
    Studio37
    Check out
