Activity Forums Apple Final Cut Pro Legacy AJA IO: FCP cannot find IO on it’s own
  • AJA IO: FCP cannot find IO on it’s own
    Posted by Adam Vincent on August 28, 2007 at 6:53 pm
    When I launch FCP, open a project and hit the space bar, I get the beachball. I have to refresh audio/video devices to get playback. This happens randomly while in the middle of projects as well. I can also click on the desktop and then back to FCP and get playback or launch another application and quit it, and get playback. ..but everytime I start FCP I have to do one of these things to get playback. Playback seems to be the only thing effected.
    I’ve been talking with AJA, but they’re at a loss at the moment.
    Here’s what I’ve tried:
    Swapped with another IO
    swapped firewire cables and ports
    reinstalled IO drivers
    zapped PRAM
    Rebuilt permissions
    copied media to system drive and played from there
    G5 firmware is 5.1.4f0
    any ideas?
    I posted this on the IO forum as well.
    Adam Vincent, Alabama Public Television
    Dual 2 GHz G5 PCI-X
    2 G RAM
    OS X 10.4.10
    AJA IO, AJA Kona LH
    ATTO UL4D
    Medea RTRX 1.3 TB stripped with ATTO express stripe
    UL4D in slot 4, Kona LH card in slot 2
    FCP 5.1.4
    Quicktime 7.2.0
    Adam Vincent replied 19 years ago 5 Members · 5 Replies
  • Walter Biscardi
    August 28, 2007 at 7:37 pm
    Did you by any chance connect the Io to the G5 while the Io was powered on? Could cause an issue with or even fry your Firewire port.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Michael Gossen
    August 28, 2007 at 8:56 pm
    So this problem doesn’t occur when the iO is not connected? Are you viewing through an external monitor? Have you trashed the FCP preferences? Any other iO prefs? Does this happen with other users?
    Michael Gossen
    Pixel Dust Digital
    https://www.pixeldustla.com
  • Ernesto Sanchez
    August 28, 2007 at 9:46 pm
    Any other firewire device connected?
    Ernesto Sanchez
    ProMax, Inc.
    E: ernesto.sanchez@promax.com
  • Jason Lyons
    August 29, 2007 at 3:55 am
    Adam,
    Had many crashes? Have you run Disk Warrior on your boot up drive? How long has it been since you have reinstalled OS & FCP? How much free hard drive space do you have on your media drives?
    Ernesto has a good point, make sure no other fire wire devices are on the fire wire bus.
    j
  • Adam Vincent
    August 31, 2007 at 9:09 pm
    Well, looks like my problem was QT 7.2. I had to do an archive install of the OS to get rid of it. So far so good, but I had to re-install all my drivers…ugh!
    Dual 2 GHz G5 PCI-X
    2 G RAM
    OS X 10.4.10
    AJA IO, AJA Kona LH
    ATTO UL4D
    FCP 5.1.4
    Quicktime 7.2.0
