Activity Forums Apple Final Cut Pro Legacy AJA Io Codec for SDI capture
  • AJA Io Codec for SDI capture
    Posted by Tim Wojcik on June 23, 2008 at 1:34 pm
    Hi. We are using a Mac Pro with Aja IoHD box.
    What codec of timeline is the “best” most suitable for SDI capture and export via Aja IoHD (from, to Digi Betacam) Apple pro res?
    thanks for the help.
    Michael Alberts replied 18 years, 2 months ago 3 Members · 2 Replies
  • Gary Adcock
    June 23, 2008 at 2:30 pm
    [Tim Wojcik] “What codec of timeline is the “best” most suitable for SDI capture and export via Aja IoHD (from, to Digi Betacam) Apple pro res? “
    In Standard Def you can choose any number of options for recording, While the IoHD is specifically designed for capture into the high quality ProRes codec, you also can work in any of the current flavors of compression widely used in SD, from Uncompressed 10 bit to DV.
    Even though all HD recording is limited to the ProRes codecs. SD is wide open
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Michael Alberts
    June 23, 2008 at 5:41 pm
    Since you are talking about SD and not HD, you’re likely to get comparable results using DVCPro50 instead of ProRes yet get smaller files sizes. However, the DVCPro50 codec is 8 bit while the ProRes can be either 8 bit or 10 bit.
    Michael Alberts
    Ambidextrous Productions, Inc.
    http://www.ambidextrous.net
