Activity Forums AJA Video Systems AJA IO & Apple Color
  • AJA IO & Apple Color
    Posted by Jussi Buckbee on February 11, 2008 at 1:36 pm
    I have an old & faithful AJA I/O dating back to 2004. I’m currently
    using it with an Intel Mac & FCSP 2. I can’t monitor Color with AJA
    I/O. Is there a workaround? AJA doesn’t seem to be interested in
    my queries about a software upgrade. Or is it Apple that is lagging
    behind? I’d like to keepeth ye olde faithful. Anybody… br…jb
    Rainer Wirth replied 18 years, 7 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    February 11, 2008 at 4:46 pm
    Unfortunately, your workaround is to not use the Io. The only Io product that works with Color is the Io HD, and that’s only working with SD. If you really want the most monitoring options for Color, consider a Mac Pro with a Kona card.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Jussi Buckbee
    February 12, 2008 at 4:16 am
    thanks for your note Arnie,
    I received a nice note from AJA stating that
    Apple is the instance to talk to when it comes
    to new drivers for AJA I/O. So, unless they come
    up with it…
    I have a Kona LHe on my other station and it
    works just fine.
    br…jb
    JBuckbee – Finland – PAL
  • Rainer Wirth
    February 12, 2008 at 11:42 am
    Colour is designed to work uncompressed on a high level (HD or ProRes). It doesn’t like breakoutboxes with FW connections. That’s the problem with IO. To work properly you have to use a card (Kona3 for example. It works also together with IO)
    Rainer
