Activity Forums AJA Video Systems AJA Control Panel Down Conversion Bug
  • AJA Control Panel Down Conversion Bug
    Posted by Tim Hull on July 26, 2005 at 7:35 pm
    When we set Downconversion to “Crop” in the AJA Control Panel, and then open ETT in FCP4.5, the setting reverts back to “Letterbox”. When you drop a sequence in the ETT window, the setting will revert to Letterbox. Only when you see the “Ready to record…” dialog, will the Crop setting stick.
    Has anyone else experienced this?
    Dual 2.5G G5, OS X 10.3.8, FCP 4.5, AJA Driver 1.1.2, Kona 2 with KBox
    Tim Hull
    Digital Desktop Consulting
    Craig Ernst replied 21 years, 2 months ago 3 Members · 2 Replies
  • Jared Picune
    July 26, 2005 at 11:57 pm
    I have noticed behavior like this with the Reference input as well. I don’t think that it is a bug, but rather the Control Panel knows that there are different modes in FCP and automatically changes when they are entered. Then again maybe it is just a bug.
    Have you tried to save a preset to avoid the auto switching?
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
  • Craig Ernst
    July 27, 2005 at 6:10 am
    Presets do not help, just a bug, at least you caught it. What I’ve found as a solution is to hit escape ONCE right after the computer starts to capture the first clip in a batch, I simply click over the the AJA control panel, reset my settings and hit continue in FCP, small anoyance, but not tooo bad, I wish it was not like that but it is even on a completely clean system.
    Craig
