Activity › Forums › AJA Video Systems › AJA Audio Bad, Line out Good
  • AJA Audio Bad, Line out Good
    Posted by Bob Cole on September 10, 2007 at 2:39 pm
    short version: I captured material via HDV, which played back fine. I then added a new Convergent Design HD-Connect MI, captured material via SDI (ProRes422). The capture quickly aborted due to “VTR Problem.” I then disconnected the HD-Connect’s Firewire-to-RS422, and captured the tape as an uncontrollable device (w/o timecode of course).
    Result: audio clicks, sync problems, dropped frames.
    Added Result: HDV files have same problems, despite playing properly before.
    I have done everything I can think of: trash prefs, uninstall Kona software, restart, use Kona VTR Xchange, isolate computer from all firewire inputs (which fixed a similar problem once).
    Oddly, I can play the HDV captures with no issue, as long as I use FCP/Audio-VideoSettings/Audio Line Out. But when I switch that setting back to AJA Kona audio, I get the audio clicks and dropped frames.
    Eventually I’d like to make the HD-Connect work, but for now I’d be happy to be back in business, and fix the problem which using the HD-Connect apparently triggered.
    Long version:I’ve been having problems for a long time when trying to use my Kona LHe for high definition captures. Here’s an earlier thread: https://forums.creativecow.net/readpost/98/865467
    Is this a hardware issue? Since I keep having similar problems, any basic suggestions? Including hiring a local FCP guru to come in and fix everything?
    Bob Cole
    MacPro 2 x 3GHz dualcore; 2 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
    Walter Biscardi replied 19 years ago 4 Members · 16 Replies
  • 16 Replies
  • Jeremy Garchow
    September 10, 2007 at 3:19 pm
    What is your reference set to in the Kona CP?
  • Bob Cole
    September 10, 2007 at 3:25 pm
    [JeremyG] “What is your reference set to in the Kona CP?”
    freerun
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
  • Jeremy Garchow
    September 10, 2007 at 3:35 pm
    Does the HD Connect accept reference? Have you tried referencing the HD Connect and Kona?
    It sounds like a ref issue to me.
    Jeremy
  • Bob Cole
    September 10, 2007 at 4:03 pm
    [JeremyG] “Does the HD Connect accept reference? Have you tried referencing the HD Connect and Kona?”
    No reference into the HD Connect (the picture on the HD Connect capture looked fine.)
    I still have the problem after taking the HD-Connect out of the loop entirely (disconnected every wire to it). I’ve done all the normal things: deleted prefs, reloaded Kona software (three times so far), restarted MacPro…
    Just captured a short HDV clip. It plays back fine until I try Audio-Video Settings: AJA Kona audio.
    I took your earlier advice and made Kona CP visible to see whether the ref in setting changes — it’s still Free Run.
    It’s really odd that when I play back a previously successful clip, I get the same lost frames/audio clicks. This is very bad for me, because I have a deadline of tomorrow on an edit that I apparently can’t use the Kona card to export now.
    I wonder whether it’s hardware. But it’s so strange that this problem came back just when I tried SDI input.
    I am in rather desperate straits at this point, and would appreciate any advice! It must be something so simple I can’t think of it.
    Thanks for your help.
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
  • Jeremy Garchow
    September 10, 2007 at 4:17 pm
    Have you used an AJA Kona HDV easy setup?
    Jeremy
  • Jeremy Garchow
    September 10, 2007 at 4:23 pm
    What version of FCP, QT, and Kona drivers is everything?
    Did you uninstall the Kona drivers before reinstalling?
  • Bob Cole
    September 10, 2007 at 5:25 pm
    Thanks Jeremy. This seems to be a very weird hardware problem.
    (to answer your good questions, FCP, QT, Kona all up-to-date. I uninstalled Kona before reinstallation.)
    Under guidance of AJA tech support I swapped out the break-out box, found the problem disappeared. Then I reinstalled the break-out box and selectively plugged in various inputs/outputs. When I unplugged the Analog Video In, the playback problem disappeared. Go figure. The Analog Video In actually works for input — but aborted the playback.
    Further muddle: when I replugged the Analog Video In cables, everything now works. So AJA is now replacing the break-out box and the umbilical.
    Does this make any sense at all?
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
  • Jeremy Garchow
    September 10, 2007 at 7:06 pm
    [Bob Cole] “Does this make any sense at all?”
    Not really. Glad AJA was able to track it down.
    Thanks for posting the results.
    Jeremy
  • Bob Cole
    September 10, 2007 at 7:17 pm
    Thanks for helping out. When your deadline is looming and you have one machine, and it ain’t workin’… it’s mighty nice to get a helping hand.
    Bob C
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
  • Jeremy Garchow
    September 10, 2007 at 7:35 pm
    No worries, Bob.
    Hope it new BOB solves it all!
    Jeremy
