Activity › Forums › AJA Video Systems › Aja and the nvidia chipsets?
Posted by Tim Veal on April 30, 2007 at 9:25 pmDoes anyone know if the Xena boards are compatible with the new Nvidia nForce 600 series motherboards?
Tim Veal replied 19 years, 3 months ago 4 Members · 6 Replies -
Szumlins
May 1, 2007 at 3:26 amThis might help out a little when looking to build a system:
https://www.aja.com/html/support_xena_rec_sys.htm
-Mike -
Tim Veal
May 2, 2007 at 3:47 amThanks. I was looking for something like this and couldn’t find it. I saw all the boards listed are dual AMD/Xeons. Is anyone using a Core 2 Duo board?
Kevin Christopher
May 2, 2007 at 6:05 pmProbably not. You really need a workstation class motherboard for uncompressed HD. All of the Xeon boards/systems listed are dualcore/quadcore Xeons. Plenty of speed there. The real test is in the chipset/bus architecture. That is where you will find the workstation boards more stable and better for handling Uncompressed HD.
Kevin
Tim Veal
May 2, 2007 at 10:54 pmSo it’s more of a speed issue rather than a compatability issue? I would be using the Cineform codec and using the Xena for capture/monitoring/output. Not even close to the horsepower needed for uncompressed.
Ramona Howard
May 7, 2007 at 3:19 pmKevin,
Actual both server and workstation boards work for uncompressed HD. There really isn’t much going on with the procs, given your using the right I/O card for the job 🙂
We have used a mixture of both and on both Intel and AMD over the years.
Cheers,
RamonaRamona Howard
SpectSoft, LLC
593 Hi-Tech Parkway Suite B
Oakdale, CA 95361
Phone: 209.847.7812 extension 104
Fax: 209.847.7859
https://www.spectsoft.comRaveHD – Changing the way you think about HD
Tim Veal
May 8, 2007 at 2:03 pmThanks for all the replys. A Core 2 Duo board fits in my budget for my startup system so I’ll try that first with my setup and see how the card works and post the results.
