Activity Forums Panasonic Cameras AJ-HD1400 firewire connection – can it downconvert?
  • AJ-HD1400 firewire connection – can it downconvert?
    Posted by Galen Yeo on July 25, 2007 at 7:57 am
    Want to check if the AJ-HD1400 deck can do downconverts via menu settings or does it just output the pure DVCPro HD signal from tape.
    We are trying to lay off dubs to a Sony dv deck with timecode, but it does not seem to work!
    We will go the usual SDI route otherwise but any help would be appreciated….working with a loan deck now.
    Thanks in advance
    Kimberlee Mctaggart replied 19 years, 1 month ago 4 Members · 4 Replies
  • Chris Bierlein
    July 25, 2007 at 1:48 pm
    The deck will downconvert through the firewire. It’s under the 800 menu settings (894 would read 002 if you want to output DV from a DVCPRO HD tape.)
    CB
    http://www.chrisbierlein.com
  • Galen Yeo
    July 26, 2007 at 4:54 am
    thanks. will give it a shot. I assume if it’s playing out a DV tape on the deck that it will need to be adjusted as well? will check anyways.
  • Ron James
    August 10, 2007 at 8:21 pm
    Does not do what it says it’s supposed to do. No matter the menu settings. I’ve been through this every which way and I hear of others with the same problem. If someone says it can be done, I doubt they’ve done it and would only believe it to see it for myself.
  • Kimberlee Mctaggart
    August 28, 2007 at 12:25 am
    I cannot get it to work either!!
    Kim
