Activity › Forums › AJA Video Systems › AJ-1400 audio issues
  • AJ-1400 audio issues
    Posted by Paul Turlick on December 4, 2007 at 5:39 pm
    Hi-
    Wondering if there are any known audio issues with outputting HD 1080i to the AJ-1400. I know the FW output has its issues but I’m coming out SDI from my Kona LHe into the HD SDI on the deck. Video is all good but the audio is “crunchy” for lack of a better term. Material was brought in via FW but I’m outputting from the card (I didn’t have the card when I digitized) and wondering if that’s giving me this nonsense…
    Any thoughts?
    Thanks.
    Paul Turlick replied 18 years, 9 months ago 5 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    December 4, 2007 at 5:51 pm
    Call AJA right now.
    Jeremy
  • Paul Turlick
    December 4, 2007 at 5:58 pm
    will do. strange thing is I outputted to digibeta with no issues….
  • Walter Biscardi
    No issues at all here using HD-SDI to layback.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Jeremy Garchow
    December 4, 2007 at 6:03 pm
    Yes, it’s intermittent.
    Jeremy
  • Simon Sommerfeld
    December 4, 2007 at 6:23 pm
    Hi Paul,
    I’ve had something similar to what you’re describing happen with a Kona2. I tracked it down to a setting in the Kona control panel. One of the Kona SDI inputs fed from a deck was selected as the input source but the deck wasn’t turned on. Darn thing caused static in the audio. I deselected the SDI and the audio was clean. Could be a different scenario from you, but worth looking at.
    Best,
    Simon.
    Simon Sommefeld
    Redwood City CA
  • Paul Turlick
    December 4, 2007 at 7:26 pm
    My penance……
    DOH!
    Operator error.
    Broke the first rule of troubleshooting by not checking my connections. Breakout box cable somehow became loosened. Seems to have fixed the issue.
    As always thanks so much for the quick responses.
    -Paul
  • Jeremy Garchow
    December 4, 2007 at 8:43 pm
    [Paul] “DOH!
    Operator error. Breakout box cable somehow became loosened. Seems to have fixed the issue. “
    Oh, you mean it was one of those EASY fixes?
    Huff. Puff. Huff.
  • Paul Provost
    December 5, 2007 at 5:01 am
    you’re lucky Bob Zelin hasn’t seen this post.
    you’d get an a?% chewing
  • Paul Turlick
    December 5, 2007 at 6:17 pm
    believe me….I know. Problem is it would be deserved. I figured at least I fessed up.
