Activity Forums Apple Final Cut Pro Legacy Airplane or Airport-like voice over
  • Airplane or Airport-like voice over
    Posted by Dit Ben on October 21, 2006 at 10:29 am
    Does anyone have an idea what final cut audio plugins I could use to turn a voice that I will record (slow and impersonal on purpose) to sound like it was recorded in an airplane or at an airport (you know, those public announcements?)
    _adam_ replied 19 years, 10 months ago 5 Members · 5 Replies
  • Jerry Hofmann
    October 21, 2006 at 12:04 pm
    I think the echo/reverb will give the impression that its being heard at an airport…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Dit Ben
    October 21, 2006 at 2:58 pm
    I tried that, but Im also trying to get the kind of muffled sound you hear through airport loudspeakers or a plane’s PA system. I tried with an eq that enhances low frequencies. Makes it better, but not quite there. Any other ideas?
  • Peter Wiggins
    October 21, 2006 at 3:43 pm
    You probably need to compress it, add a bit of distortion and eq..
    try running it through soundtrack, bitcrusher etc
    Peter
    Free Motion Templates
    peterwiggins.com
  • Will Salley
    October 22, 2006 at 4:16 am
    An airports PA system produces a vastly different sound space than an airplane’s.
    To emulate the airport terminal, use some slight reverb and some short delay with about two or three reflections, and use an old, beat up mic inside a sock. Another trick is to record the announcement and then playback that announcement through a less-than-high-fidelity system and re-record the playback while micing it from a distance. A large room (like a gymnasium) will sound best but even a bathroom will work.
    For the airplane, just a some slight and very short delay, then roll off the highs. The sock on the mic might help too.
    Ambient sfx will sell it better than anything, however.
  • _Adam_ Create COW Profile Image
    _adam_
    October 22, 2006 at 8:07 pm
    Or try re-exporting the audio files, but at a much lower sampling rate (like 8 or 16khz), that (should) give it a nice “weak” effect… then pull those back in & reverb away.
    Adam
