Activity Forums VEGAS Pro Air Traffic Control Audio filter
  • Mike Kujbida
    March 24, 2010 at 3:37 pm
    If you mean something like a telephone sound, try the “Phone line effect” built into the Parametric EQ audio FX that comes standard with Vegas.
  • Jeff Schroeder
    March 24, 2010 at 6:10 pm
    Thanks Mike, I had a few filters stacked up, and was getting a failrly good sound. I’ll add that one to the mix and see what I come up with.
    Jeff
    http://www.narrowroadmedia.com
  • Ben Longden
    March 27, 2010 at 2:21 am
    Just have a listen to the real thing so you can write the correctly phrased script… Nothing cheeses pilots and aviation folk off more than incorrect radio calls….
    As for the filter, try the phone first. Remember the radios are AM, narrow audio bandwith, and unless youre a jet jockey where the cash converters are at the back of the plane, there will be considerable background noise, even from the David Clark noice cancelling mics.
    Ben
    (cash converter = engine. It converts cash into thrust to propel the aircraft)
    Do unto others…
