Activity Forums Adobe Illustrator AI Box outline
  • AI Box outline
    Posted by Rocky Lam on May 12, 2008 at 7:45 pm
    I am using AI to create logos. For example the logo is retangular shape with blue background. When I place that logo in another document with same blue background. I see the white outline of the logo. How can remove that white outline so the logo blend in with the rest of the document?
    Adolf Witzeling replied 18 years, 4 months ago 3 Members · 5 Replies
  • Joe Hayden
    May 12, 2008 at 8:34 pm
    Its likely a stroke on your rectangular path. Highlight the rectangle–open the stroke window and set stroke to 0.
    Cheers,
    Joe
    L.O.A.
  • Rocky Lam
    May 12, 2008 at 8:51 pm
    I tried the window strobe is still shown the border line.
  • Adolf Witzeling
    May 13, 2008 at 5:52 pm
    Are you placing the Illustrator file in InDesign?
    If yes, go to VIEW…HIDE FRAME EDGES.
    See if that helps.
    cheers,
    Adi
  • Rocky Lam
    May 13, 2008 at 9:24 pm
    I am placing the logo on an Excel sheet document. I am working on pricelist documents.
  • Adolf Witzeling
    May 14, 2008 at 2:39 pm
    Oh, ok.
    In Illustrator, before you save the logo, go to EFFECT….RASTER EFFECT SETTINGS.
    In the Options check CREATE CLIPPING MASK around the logo. Make sure the “add … around object is set to ZERO.
    Maybe that’ll work.
    cheers,
    Adi
