Activity › Forums › Adobe After Effects › Aharon Rabinowitz’s Cartoon tutorial.
Posted by Cj Stewart on December 12, 2006 at 9:26 pmIllustrator wont batch process.
i did everything right….
ANY HELP?
PLease i need to finish this project. ThanksCj Stewart replied 19 years, 8 months ago 2 Members · 7 Replies -
Aharon Rabinowitz
December 12, 2006 at 10:17 pmMake sure you got the script exactly right, and that you actually saved it. Go in and tripple check it.
Unless the batch option is not available at all (and that has happened to some people) It’s almost definately a problem with the script.
That’s the only advice I can give you. Sorry.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Cj Stewart
December 13, 2006 at 7:41 amOnce i go to tools, illustrator live trace then i pick my preset and a place to save. after i press ok, it seems like it does something but when i got to the folder, nothing happens.
Aharon Rabinowitz
December 13, 2006 at 4:05 pmI would suggest you try it first with the orignal script and see if it works – it will only do 10, but at least you can test it.
Then if it works, copy the script again and use the new copy to try and redo the script. You may have inadvertantly messed up something else in the script an not realized it. It’s happened to me.
Aharon Rabinowitz
Cj Stewart
December 17, 2006 at 8:48 amyes, thanks alot. that worked.
I still cant process more than 10 though because the live trace script lines are different than yours. Is there a way i could contact you via email?
Thanks alot. -
Aharon Rabinowitz
December 17, 2006 at 2:20 pmLets try and solvew the problem here. THat way other people who are having the same problem can get help as well. Also, one of them may have already solved your problem.
[weezhum] “I still cant process more than 10 though because the live trace script lines are different than yours.”
Do you mean the line numbers? You need to find the line with the same text – the line numbers are unimportant. It varies I’m told.
If it’s not the numbers but rather the code that varies, I’m by no means an expert on this. I got a lot of help for this, one, but I’ll see what I can do. Please give some fine details here.
Aharon Rabinowitz
Cj Stewart
December 17, 2006 at 11:20 pmThanks alot. When i get to my work computer i will post my issues on here. Thanks alot for your quick responces.
