Activity › Forums › Panasonic Cameras › AG-HPG10 Portable P2 Gear Player/Recorder and Canon XLH1
  • AG-HPG10 Portable P2 Gear Player/Recorder and Canon XLH1
    Posted by Carlo Ferraro on September 10, 2009 at 10:55 pm
    Can someone tell me if it is possible to record from Canon XLH1 directly into the AG-HPG10 Portable P2 Gear Player/Recorder by Firewire or SDI ?
    Jeremy Garchow replied 17 years ago 3 Members · 5 Replies
  • Jeremy Garchow
    September 10, 2009 at 11:09 pm
    Sdi for sure, but probably not FireWire.
  • Carlo Ferraro
    September 10, 2009 at 11:23 pm
    Jeremy:
    My question is more towards the codec since the output of the camera is 1440×1080, 1080i.
  • Jeremy Garchow
    September 11, 2009 at 1:24 am
    That’s the tapeless version. Coming out of the SDI Is ucomprssed video. With that recorder you can capture to full raster 10bit AVC-I mxf files. Much better than the hdv of the canon.
  • Jan Crittenden livingston
    September 11, 2009 at 3:34 pm
    The AG-HPG10 only has 1394 as an input and so it is looking for a compatible codec to come in on a compressed domain. This means that only the DV codec generated by the GH1 is compatible. However, since the AG-HPG20 has an HD-SDI in, it could be used to record into DVCPRO-HD or AVC-Intra fro the HD-SDI out put from the GH1.
    I hope this helps,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HPX300, HPX170, HVX200A
    Panasonic Broadcast & TV Systems
  • Jeremy Garchow
    September 11, 2009 at 3:35 pm
    Woops, sorrry about that. I meant the HPG20.
    Jeremy
