Activity › Forums › Adobe After Effects Expressions › AFX Script Problem Visual Studio Code
  • AFX Script Problem Visual Studio Code
    Posted by Martin Müller on July 14, 2021 at 7:10 pm
    i recently started scripting and wrote a script in VS Studio for After Effects, which works fine when i run it from Visual Studio. But when i save it and run the script from After Effect it gives me an error message: “unable to execute at line 20…”
    which is a function in my script. everything before gets executed.
    I have Variables (a,b) in my function because i am looking for several Objects meaning CompItem, FootageItem, Folderitem where I’m looking for specific names as a string.
    The Function looks like that:
    function graballItems (a,b){
    var proj,curItem,itemTotal,ItemAry;
    proj = app.project;
    itemTotal = proj.numItems;
    ItemAry = new Array();
    for (var i =1; i<= itemTotal; i++){
    curItem = proj.item(i);
    if (curItem instanceof b && curItem.name.indexOf(a) !== -1 ){
    ItemAry = curItem;
    return ItemAry;
    And i use it like that:
    var myCompBeauty = graballItems(“CAN_ENDTAG_PRE”,CompItem);
    But strange though, that it is working from VS Studio.
    Does anybody know why the error message appears?
    Cheers
    Martin
    Tomas Bumbulevičius replied 5 years, 2 months ago 2 Members · 1 Reply
  • Tomas Bumbulevičius
    July 21, 2021 at 8:44 pm
    Hey Martin, it would be better if you share specifically a line 20 (to know where error is coming at) and all lines above which are related.
    In addition, please share whole error message – as now its truncated and might point out to the problem by itself.
