Activity Forums Adobe After Effects AFX: How to restrain particles INSIDE a shape ??
  • AFX: How to restrain particles INSIDE a shape ??
    Posted by Michele Busiello on January 24, 2011 at 11:19 am
    Hi!
    i want to animate a stylized 2d-shape of a sandclock in after effects. The sand will be animated with trapcode particular. Now i was wondering if its possible to restrain all the particles inside that sandclock shape..in order to let the particles bounce of the shape walls etc. that would look by far more realistic then just adding a simple mask. any idea how to do this ?
    Walter Soyka replied 15 years, 7 months ago 5 Members · 6 Replies
  • Darren Chappell
    January 24, 2011 at 12:53 pm
    My basic knowledge of AE and Particular says — YES – -WOOP WOOP.
    Create your particles (size I suspect to be ‘very’ small.
    You will need to create a crude ‘closed’ imaged of your hourglass using multiple 3D layers (All rotated to be end on….)
    Using the ‘bounce’ facility (I think its in physics) to will need to define you ‘floor / walls’
    Increase your life, so to retain the structure . .
    Only question I have, is whether the particles will ‘pile’ or just overlap – must be a way round that – will need to think.
    And when I get home from work, PLAY…..
  • Walter Soyka
    January 24, 2011 at 1:51 pm
    Particular lets you define a wall and a floor for Bounce physics, but even with these, you won’t have the ability to pile up particles like in an hourglass.
    This might be better handled with a 3D application (like Cinema 4D or Blender) with a particle system and dynamics.
    Walter Soyka
  • Tudor “ted” jelescu
    January 24, 2011 at 3:26 pm
    Two particle systems/generators – one for the sand that falls down, one for the sand that piles up…? Could be interesting.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Michael Szalapski
    January 24, 2011 at 3:28 pm
    A 3d program will get you much more what you want, but if it must be AE, you could try using Foam. You can use a precomp as a flow map to guide the particles and they will react to each other somewhat. You’ll have to play with the settings so that they don’t kill each other when they hit. (The initial settings are more for bubbles or…FOAM as you might expect.)
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
    January 24, 2011 at 4:04 pm
    This tutorial may help also. You could use this technique to shape the particle flow.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Walter Soyka
    January 24, 2011 at 5:53 pm
    [Tudor "Ted" Jelescu] “You could use this technique to shape the particle flow.”
    Good call!
    You could also use a couple instances of Particular and shape the particle flow with Particular’s Air > Motion Path feature (which would let you avoid any distortion the Puppet tool would introduce).
    Walter Soyka
