Activity › Forums › Adobe After Effects › afx crashes on startup
  • afx crashes on startup
    Posted by Satesh Ramjattan on February 13, 2006 at 1:36 am
    hello,
    i recently installed AE7 in trial mode, but once it begins to load at the splash screen, specifically on
    openGL, it just closes.
    anyone have this problem or a solution? i still have AE 6.5 installed and has worked fine since installed.
    thanks
    Alan Mills replied 20 years, 7 months ago 4 Members · 4 Replies
  • Christopher R. green
    February 13, 2006 at 3:45 am
    Might be a font. This happened to me. Removing all my self-installed fonts removed the problem, then it was a simple process of elimination to find the wacky font. (On OSX, this kind of thing is a good argument for installing non-standard fonts only in your home/library/fonts directory.)
    (mentioned in an earlier post, somewhere down there … )
  • Satesh Ramjattan
    February 13, 2006 at 2:22 pm
    i think it’s funky that i can open 6.5 just fine, and not 7.
  • Betty Boop2
    February 13, 2006 at 9:45 pm
    I had that happen, I had to update my display driver and the problem went away.
    Hope this helps.
    Jay Thompson
    Thompson Visual Design & Storytelling
    7 Marjean Ct.
    Kirkwood, MO 63122
  • Alan Mills
    March 4, 2006 at 4:29 pm
    Thank you for this answer. I installed AE7 (along with the rest of the Production Studio) last night and had this exact issue. I updated the drivers as suggested and the problem is went away imediately.
    Thanks again.
    Alan
