Activity Forums Apple Final Cut Pro Legacy Aftger Effects graphics look crunchy in FCP
  • Aftger Effects graphics look crunchy in FCP
    Posted by Doug Normington on August 16, 2010 at 3:03 pm
    Hi, I am editing a project in Final Cut Pro. Standard Def DV 16:9. I have made some animations in Aftereffects with the composition settings of DV wide screen. When I output the animations as quicktime they look fine in the quicktime player. When I bring them into Final Cut Pro they look fine when I step through then frame by frame but when I render the sequence the edges of the font looks frayed.
    I have tried field rendering. Non field rendering. different codecs. not sure how to crack this one.
    thank you in advance.
    Doug
    Rafael Amador replied 16 years ago 4 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    August 16, 2010 at 4:13 pm
    Hi Doug,
    Change your sequence codec to something better than DV (DV50, 8/10b Unc, Prores), and you will see the difference.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Doug Normington
    August 16, 2010 at 4:34 pm
    I have used prorez50 and 8 and 10 bit and it looks the same. Kind of frayed on the edges. The font is generated in aftereffects…
    Doug Normington
    NORMCO Multi-Media, Inc.
    (608) 824-0999 Office
    (608) 345-7579 Cel
  • Rafael Amador
    August 16, 2010 at 5:30 pm
    Are you watching the canvas at 100% and fully rendered?
    Did you tried to change the Alpha Channel of the graphics?
    rafael
  • Chris Tompkins
    August 17, 2010 at 2:04 pm
    Render your AE grfx DV50.
    Drop ur DV footage into a DV50 Timeline.
    Render.
    View Ext. monitor.
    Chris Tompkins
    Video Atlanta
  • Kai Cheong
    August 17, 2010 at 2:37 pm
    I had a similar issue during edit today which involved Livetype. Maybe my solution would help your situation: check the AE Quicktime you’ve dragged into the browser. Scroll across to the field order column – what’s listed there?
    Oddly enough, even though I’d exported a ‘no fields’ Quicktime from Livetype, when it was brought into the browser, it was tagged as ‘Upper (Odd)’. I changed that to ‘none’ and replaced the clip in the sequence – problem solved.
    Kai
    FCP Editor / Producer with Intuitive Films
    https://kai-fcp-editor.blogspot.com
    Now ‘LIVE’! Check Out The Intuitive Films Blog @ https://intuitive-films.blogspot.com
    At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
    Visit us @ https://www.intuitivefilms.com
    MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.7
    8-Core Intel Mac Pro 2.26GHz | 8GB RAM | FCP 6.0.6 | Mac OS X 10.5.6 | 3.0TB CalDigit VR | 2 x 24″ Dell S2409W
  • Rafael Amador
    August 17, 2010 at 2:38 pm
    [Chris Tompkins] “Render your AE grfx DV50.”
    No Alpha channel.
    rafael
  • Chris Tompkins
    August 17, 2010 at 8:47 pm
    Did not see any mention of Alpha in original post…
    Chris Tompkins
    Video Atlanta
  • Rafael Amador
    August 18, 2010 at 1:30 am
    [Chris Tompkins] “Did not see any mention of Alpha in original post…”
    Well, when people talk about “Graphics”, I imagine an Alpha channel.
    rafael
