Activity Forums Avid Media Composer AfterEffects EMP causing Flamethrower Errors?
  • AfterEffects EMP causing Flamethrower Errors?
    Posted by Milton Hockman on October 18, 2006 at 5:00 pm
    I installed the EMP plugin so that i could preview AE and Avid on my tv montior.
    Well, since i installed it and got effects crazy in Avid, i began to get a “Flamethrower error…..200 milliseconds” error or something like that.
    i could not open up AE at the same time as avid or this would happen.
    so i uninstalled the EMP plugin and now everything is fine.
    anyone know what can be done?
    Michael Hancock replied 19 years, 6 months ago 2 Members · 1 Reply
  • Michael Hancock
    October 18, 2006 at 5:48 pm
    I may be totally wrong about this, and if I am someone will hopefully correct me, but EMP allows AE to route a signal to your client monitor using the same resource as Avid–like a Mojo, right? If you have them both open they’re fighting over it, and Avid is like a two year old–sweet as pie but doesn’t like to share and throws a temper tantrum when you make it. Otherwise, use them one at a time and you should be good to go. Again, I could be way off base, but I’m guessing that’s what’s happening.
    Mike.
