Activity › Forums › Adobe After Effects › AfterEffects CS5 showing only 4 gig of RAM
  • AfterEffects CS5 showing only 4 gig of RAM
    Posted by Jonathan Capra on March 21, 2011 at 10:22 pm
    Just installed Windows 7 64-bit and AfterEffects CS5. Did a test render on an existing project and the Render Queue shows that it is only addressing 4gig of RAM. The system has 8.
    Is there a setting that needs to be changed, even in CS5, in order to address more than 4gig of RAM? I thought this might be a common issue, but I googled and scanned this forum and couldn’t find much.
    P.S. Are there any settings that should be tweaked for multi-processing, multi-threading, etc?
    Jonathan Capra replied 15 years, 6 months ago 3 Members · 4 Replies
  • Brian Charles
    March 22, 2011 at 1:42 am
    If your computer has more than one processor or core you need to enable multiprocessing in After Effects Preferences> Memory and Mutliprocessing.
    However, 8Gb of RAM is not really sufficient to take advantage of multiprocessing since each process can access 3Gb.
    Start here: https://help.adobe.com/en_US/aftereffects/cs/using/WS9F936D13-E76A-41e4-BF8F-577132AB4723a.html
    Then read Todd Kopriva’s comments here:https://forums.adobe.com/thread/543440
  • Walter Soyka
    March 22, 2011 at 2:42 pm
    AE CS5 on a 64-bit system does away with those old memory limitations.
    I’d suggest looking in Preferences > Memory & Multiprocessing, and checking the amount of RAM reserved for other applications.
    Brian’s link is the best place to start on memory settings. That said, 8 GB of RAM is not a lot for AE, especially once you take multiprocessing into account. I’d say you’ll get better performance leaving a little bit of RAM unused than you would maxing everything out and forcing your system to swap during render.
    Walter Soyka
  • Jonathan Capra
    March 25, 2011 at 3:18 pm
    Yeah this machine has Windows 7 64-bit…
  • Jonathan Capra
    March 31, 2011 at 12:25 am
    Very helpful! Thank you!
