Activity Forums Adobe After Effects After Fx CS6 parenting tools “alt key”
  • After Fx CS6 parenting tools “alt key”
    Posted by Nikhil Tanenquin on May 6, 2013 at 12:08 am
    I was wondering if you have been able to understand the different parenting options with holding the alt, shift keys. I coudnt grasp the “hold alt key”. maybe someone here may have already decoded them and can explain in layman’s terms. Thanks
    Nikhil Tanenquin replied 13 years, 1 month ago 2 Members · 2 Replies
  • John Cuevas
    May 6, 2013 at 1:17 pm
    When you shift parent you probably have seen the layer will jump to the parent layer’s position. Alt+Parent moves takes it’s original coordinates(250,250) and moves the layer to the those coordinates based on the parent layer’s position. So where ever the parent layer is, that becomes 0,0 for the child layer.
    I made a little example project that should illustrate this: 5950_parentingoptions.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Nikhil Tanenquin
    August 14, 2013 at 4:13 am
    This comes late, but thank you,. It makes sense now!!
