Activity Forums Adobe After Effects After effects/Quicktime problem! HELP!
  • After effects/Quicktime problem! HELP!
    Posted by Christopher Carlsson on February 3, 2008 at 7:32 am
    Hey… I got my new computer hardware about a week ago, and I was really excited and all that untill I found out that After Effects didn’t work.. Here’s my problem: When I import a .mov to my project files, it works sometimes, sometimes it crashes (After effects has stopped workin). If it works, I can drag the clip into the comp, then it crashes.. I figuered it has something to do with Quicktime, since its only .movs it happens with.. Ive tried to reinstall After effects several times, not working. Reinstall Vista, not working.. Reinstall Quicktime, neither that works.. I have Quicktime 7.3.1, After effects CS3, And windows Vista Ultimate 32 bits.
    My Computer hardware is:
    Gigabyte x38 DS5, f5 BIOS
    Intel Core 2 Duo E8400
    Gainward 8800GT 512 Mb
    3 Gb PC6400 RAM
    And it worked before I changed the processor and motherboard.. So, could it be that after effects or quicktime is incompatable with my motherboard or cpu? The cpu havn’t even been out for 2 weeks here in sweden..
    So, do you guys have any idea why my After Effects wont work? And sorry for my bad english, Im from Sweden..
    Thanks in Advance.
    Christopher Carlsson replied 18 years, 7 months ago 5 Members · 17 Replies
  • 17 Replies
  • John Lanigan
    February 3, 2008 at 1:08 pm
    Hi Chris,
    I’ve had similar issues with After Effects and Quicktime on a 32 bit Vista OS. I’ve found a temporary workaround solution so maybe it might work for you too, when I first stumbled across the workaround in the Apple forums with other people encountering I couldn’t believe it would work but to my surprise it did.
    First off though you’ve specified that you are only encountering issues with .MOV files? Forgetting about After Effects for a minute, have you tried playing these .MOV just in quicktime, are you getting problems here, choppy playback, crappy sound, quicktime occasionally crashing etc?. As these were my symptoms, as part of my tests trying to diagnose the problem I uninstalled Quicktime and I decided to try both “K-Lite Mega Codec Pack” and also “VideoLAN – VLC media player”. Both of these media player alternatives played the .MOV files perfectly. However once I reinstalled Quicktime it had the same playback problems as previously and unfortunately After Effects only seems to accept Quicktime itself for rendering work.
    Anyway try the above tests after removing Quicktime to see if .MOV media play ok in the other media players. Anyway I digress, it appears that in my case Quicktime has a conflict with the Nvidia chipset of my motherboard, the workaround which was suggested in the Apple forums for me and which I can confirm works is to copy any .MOV files to an external USB drive, YES you read it right, once the .MOV is copied to an external USB drive the media will play correctly in Quicklime and work properly in After Effects. Go figure eh. I’m not sure if this workaround will work for you but try it out.
  • Christopher Carlsson
    February 3, 2008 at 3:18 pm
    Thank you so much for that awnser! It seems like we have the same problem, choppy play, around 16-7 fps I would say. So ill try that! Thanks!
    February 3, 2008 at 3:45 pm
    Hey again! Tha playback now works fine, no chopping here no! But.. the important part is still not good, After effects crashes the moment I import a MOV into my project files… Im gonna try to reinstall it and see if it helps!
  • John Lanigan
    February 3, 2008 at 4:20 pm
    Well hopefully the reinstall will get around your problem. Provided any of my footage is imported into After Effects from an external drive it plays fine so I hope this works for you too. Glad you had some progress.
    February 3, 2008 at 4:37 pm
    Aff… It didn’t work, still freezes the moment it hits the project files… What could do that? It doesn’t matter if its from my HDD or the USB drive, still freezes..
  • John Lanigan
    February 3, 2008 at 4:58 pm
    Ah thats unfortunate, we had seemed to be on the right track. Does quicktime ever crash on you with a “Buffer Overrun” error?
  • Austen Mathieson
    February 3, 2008 at 5:34 pm
    the problem is apple quicktime, they fckued up BIG time.
    I’ve found over 3500 complaints on various sites about QT probs.
    It’s not AE it’s QT
    Austen Mathieson
    Austentatious Productions
    February 3, 2008 at 6:14 pm
    Yes, I figuered that out a while ago 😉
    @ John: No, not what ive seen.. Im gonna see if I can record it, so you can see exacly what i mean..
    February 4, 2008 at 2:03 pm
    No one who knows whats wrong? I reaaaally need this to work…
  • Joe Moya
    February 4, 2008 at 2:26 pm
    If you are getting desperate looking for options…
    …try changing out your video card…preferable one that is NOT compatible with DX10…. in your case that would be a 7000 series instead of the 8000 series.
    I have seen situations where this can cause problems… although the problems are with Avid editiors and not so much with AE.
    I think this is a slim chance this could be your problem… but, it appears you are starting to run out of options. Hopefully, this unlikely culprit (i.e., change the video card) may save the day.
