Activity › Forums › Adobe After Effects › After effects/Quicktime problem! HELP!
Christopher Carlsson replied 18 years, 7 months ago 5 Members · 17 Replies
February 4, 2008 at 5:22 pmIm going to try to change the graphics card, I have a 7300GT that lays around here somewhere, but Im still going to need to have the 8800GT compatible with AFX, since Im gaiming, and the 7300GT is not a permanent option.. I found out that if I remove the After Effects prefrences files in the application data folder, so all settings are default, it lasts 1 second longer before it freezes, don’t know if it’s to any help, but it might do something..
Joe Moya
February 4, 2008 at 6:56 pmIf you have gaming software on your drive…
That could very well be the source of your problem…
You need a clean re-install of both OS and Adobe software (only) to be certain.
February 4, 2008 at 8:57 pmThats just what ive done 3 or 4 times… Reinstall vista, install the grapics driver and then install after effects and quicktime, still it wont work..
Mikael Hörnlund
February 5, 2008 at 3:07 pmI don’t know how to fix your problem, so I just throw out some ideas to you…
Have you tried to change your video driver? Or, try install XP instead of XP…Any other sofware that crashes? -
February 5, 2008 at 4:43 pmIt worked with this driver before, I don’t own XP and no, no other software crashes…
Mikael Hörnlund
February 5, 2008 at 5:00 pmOk.. I guess you meant before you changed your motherboard and CPU.. I would try to change the driver anyway, it worth a try, did you change you RAM as well?
February 5, 2008 at 6:40 pmOkay, ill change the driver, no, i didn’t change the RAM..
