Activity Forums Adobe After Effects After effects, X on preview
  • Grant Swanson
    May 5, 2008 at 2:51 am
    Most likely you are using a trial version of some plugin, either it’s one that came with After Effects, (are you using 7.0?) and you haven’t entered the serial number yet, or you are using a demo of some other 3rd party plugin.
    Hope that helped,
    -Grant Swanson
    https://videoapex.blogspot.com/
  • Rob Snydr
    May 5, 2008 at 2:59 am
    No, there is no trial of any plugin. My after effects has a serial and is fully registered and everything. And its not like the X that happens when you have an unserialed Trapcode plugin. It an X when i move anything such as just a blank adjustment layer on a new composition. I was playing with keyboard shortcuts when that happened, and i dont know how to get rid of it.
  • Grant Swanson
    May 5, 2008 at 12:17 pm
    Ah, I understand now. That X is what appears when you have “Wireframe” selected at the bottom of the Compostion Window. Switch it to OpenGL, Adaptive Resolution, or none, and tell me if that works.
    Hope that helped,
    -Grant Swanson
