Activity Forums Adobe After Effects After effects workflow question
  • After effects workflow question
    Posted by Keane Morrissey on February 8, 2015 at 10:49 pm
    Lets say I want to color grade my whole Final Cut project, should I grade each RAW clip individually then edit in FCP? If you do grade each RAW file wouldn’t take take too long since I only use a portion of the raw clip? or should I import that whole, edited, FCP project to Grade in after effects? How do you color grade each individual clip when after effects recognizes your edit as a single clip?
    Keane Morrissey replied 11 years, 7 months ago 2 Members · 3 Replies
  • John Cuevas
    February 9, 2015 at 2:53 am
    If you did it in AE, I would use the split clip command (shift+cntl+D). You could also try Edit Detection Script
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Keane Morrissey
    February 9, 2015 at 4:34 am
    Thanks for the tip. Still looking for answears
  • Keane Morrissey
    February 10, 2015 at 3:56 am
    Thanks again for your time, To anyone reading the solution is to edit using Adobe Premiere Pro which works hand in hand with After Effects
