Activity › Forums › Adobe After Effects › After Effects Won’t Render AVIs
  • After Effects Won’t Render AVIs
    Posted by Chris Kay on October 24, 2014 at 4:46 am
    I now work with AE CS6.
    I used to work with CS4.
    In CS6, when I set my render up as an AVI with No Video Codec and RGB + Alpha it doesn’t work. The render will complete and the video will play, but some frames are filled with large grey palettes (kind of like a no reception screen on TV filling a portion of some frames).
    Can anyone recommend me another format I can use for RGB + Alpha export (i want to use it in Premiere) or a solution to the problem?
    John Cuevas replied 11 years, 11 months ago 2 Members · 1 Reply
  • John Cuevas
    October 24, 2014 at 11:48 am
    Do you really need to render, you can dymanic link in CS6 to Premiere, open Premiere and import the AE project.
    If you really need to render out, I use Avid’s Codec DNxHD codec, it will create a quicktime file. Otherwise, if you are going for lossless, Quicktime Animation—large file size though.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
