Activity Forums Adobe After Effects After Effects won’t hide under Mac OSX Lion
  • After Effects won’t hide under Mac OSX Lion
    Posted by Lance Moody on August 3, 2011 at 2:10 am
    Anyone else seeing this behavior?
    Hide AE does not work. The AE windows stay onscreen.
    The hide command does deactivate AE–clicking on an AE window does not bring the app to the foreground but it doesn’t actually hide it.
    Lance
    Dave Harrison replied 14 years, 4 months ago 8 Members · 9 Replies
  • 9 Replies
  • Galen Fott
    August 3, 2011 at 3:49 pm
    Ditto here. Annoying. I’m using CS5. You?
  • Lance Moody
    August 3, 2011 at 5:08 pm
    Thanks Dave,
    Yes, I read that document when it came out. It does not mention this issue, unless I missed something. Did you see something specifically referencing the issue somewhere?
    Lance
    P.S. I am using CS 5.5.
  • Todd Kopriva
    August 15, 2011 at 8:03 pm
    What version, Lance? CS5? CS5.5?
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Adam Kois
    October 10, 2011 at 7:17 pm
    I have the same problem. Installed java thing too. also i have found that sometimes the little red target won’t appear for example if you are in the pan-behind tool, or a ramp expression. It only happens sometimes… weird
  • Robinson Sampaio
    November 27, 2011 at 6:37 pm
    Same here. Lion 10.7.2 with CS 5.5.
    And sometimes, the windows stay on top of any other application. Really weird.
  • Mark Warner
    December 7, 2011 at 4:01 pm
    It seems to be strangely attached to the CAPS Lock key. If you try to hide AE and it doesn’t, I find turning caps-lock on and off does the trick!
  • Robinson Sampaio
    December 9, 2011 at 1:21 pm
    I tried it here, right now, and the problem persists…
    But this time, the AE doesn’t hide but the windows are behind all the other applications.
  • James Kecskes
    April 18, 2012 at 8:37 pm
    Same problems here. Caps didn’t work. How annoying.
  • Dave Harrison
    May 23, 2012 at 4:13 pm
    It appears that when you Option-Click (on a Mac) the Desktop *then* hit the Caps Lock, After Effects will hide.
    AE 10.5.0.253, Mac OS 10.7.2
    –Dave
