Activity Forums Adobe After Effects Expressions After Effects – Variable Text Alignment
  • Filip Vandueren
    May 29, 2022 at 10:15 am
    Hi Lance,
    You can find an example project of mine here:
    https://imgur.com/gallery/uh1GbDu
    https://we.tl/t-3X3wBdYWIJ
  • Lance Clayton
    May 29, 2022 at 10:21 am
    Filip,
    Thank you! – this is a great resource and learning tool.
    Thanks for sharing.
    Lance
  • Lance Clayton
    May 29, 2022 at 10:51 am
    Filip,
    I applied your approach to a ‘text box’ (ie with a bounding box) vs a text layer without defined linebreak limits.
    How do you actually define the leftmost and rightmost alignments? (see that mine does’t reach the edges in a 4k comp (2x your resolution)?
    I see that your’s defines the right/leftmost by the longest word…
  • Filip Vandueren
    May 29, 2022 at 11:46 am
    Correct I used the longets line,
    currently there is no (convenient) way to retrieve the actual dimensions of a text-box using expressions.
    but you could hard-code it like
    maxWidth = 3900;
    One approach of finding out the (approximate) actual width of a textbox I can think of, is to set the value of the sourceText (at a certain time) to:
    if (time==-0.01) {
    txt="|".repeat(10000);
    style.setTracking(-250).setFontSize(10).setText(txt);
    } else { value }
    then
    thisComp.layer("txt").sourceRectAtTime(-0.01).width;
    would be a pretty accurate width.
    but that’s just purely academical and not very practical (as 90% of my solutions 😉 )
  • Lance Clayton
    May 29, 2022 at 11:53 am
    I’ve got it working nicely enough now.
    I did swap one line defining the width to 96.5% of the comp width (to accomodate for my margins to the side)
    That said, it breaks when/if you use the Scale Composition script to resize the comp. As long as no-one does that we should be A-okay.
    Thanks again for your brilliant guidance to a great solution.
    // selectorValue * textIndex/textTotal
    widths=thisComp.layer(“lineWidths”).text.sourceText.split(“,”).map(a=>parseFloat(a));
    maxWidth =thisComp.width*0.965;
    delay = effect(“delay”)(“Slider”).value;
    align = effect(“left – ctr – right”)(“Slider”).valueAtTime(time-textIndex*delay);
    (maxWidth-widths[textIndex-1])*align/10000;
