Activity › Forums › Adobe After Effects › After Effects Using Only Caps
  • After Effects Using Only Caps
    Posted by Noah Stahl on January 18, 2011 at 3:59 pm
    I was going to make a video this morning but After Effects only types in all caps and when I clicked to use small caps, it only makes the caps look smaller haha. How can I go back to have After Effects use the lowercase letters after I’m done with the caps? No matter what I do nothing helps, and I can’t find anything anywhere. This hardly happens to me since I almost know my way around anything or I can figure it out.
    Noah
    Roei Tzoref replied 9 years, 2 months ago 5 Members · 6 Replies
  • Kevin Camp
    January 18, 2011 at 4:21 pm
    first, check the character palette and make sure the icon with the 2 large t’s is not enabled (or click the menu in the upper left of the character palette and make sure there is no checkmark next to ‘all caps’) –that option forces caps, regardless of how you type it.
    second, make sure that you are not using a font that has only caps.. try setting the font to another font, like arial or one that you know has lowercase.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Noah Stahl
    January 18, 2011 at 4:23 pm
    Yeah that’s what I read, but when I turn that off, it still writes in all caps but they are smaller. Yeah I know the fonts are not all caps because I used them all before and it even does it for Arial
  • Noah Stahl
    January 18, 2011 at 4:49 pm
    Oh man thank you so much! I feel so stupid right now haha I thought that one had to always be down. Thanks for all your help. I love this forum, really fast response time for everything!!!!
    Noah
  • Jasper Bower
    April 16, 2013 at 8:21 pm
    Yesss!!! had same problem all the toggles need to be OFF, that solved it. Than you so mcuh 🙂
  • Paulo Barbosa
    June 17, 2017 at 1:43 am
    2017 and the same problem. now feeling stupid for reading this easy and obvious solution. thank you.
  • Roei Tzoref
    June 17, 2017 at 6:19 am
    Whenever you get strange character behavior, you can reset to the default character preferences by clicking at the top right corner of the panel. The hamburger menu has an option to reset.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
