After Effects transparent footage taking forever to export
Hi guys, hope you’re good.
I’ve got some footage I’ve shot against a greenscreen. I want to export it with a transparent background as it will be much quicker to edit.
However when I go to export the footage it is taking between 3-5hrs per video and they’re coming out at around 15GB each! The videos are only around 3 mins long each, so this seems very excessive.
The footage is 4K, although I’ve made the comps 1920×1920 as the bit of the footage without background fits into this space.
I’m using Render Queue and RGB+Alpha exporting to Quicktime (settings attached).
I’ve also attached my system info and AE preferences.
Is there a quicker way of doing this? Or do I just need to be patient and wait?
Cheers in advance
Oli
