Activity Forums Adobe After Effects After Effects to Flash
  • After Effects to Flash
    Posted by Simka Cvetkovic on May 13, 2008 at 9:09 pm
    Hi everyone
    I think I handle After Effects much better then any Flash software.My question is: Can I make something nice in After Effects and export it like .swf file.I need a good quality of .swf file.I need it for banners,for examples,intros…or other stuff for web.Thank you!
    Simka Cvetkovic replied 18 years, 4 months ago 3 Members · 3 Replies
  • Simon Bonner
    May 13, 2008 at 10:14 pm
    Yes you can, but I don’t believe you can do it via the render queue – you have to go via File > Export. AE also has a ready-made comp preset for web banners (toggle down the preset menu when you make a new comp).
    Simon Bonner
    youtube.com/simonsaysFX
  • Mike Clasby
    May 13, 2008 at 10:21 pm
    Here is an earlier post with lots of info.
    https://forums.creativecow.net/thread/2/922407#922418
    To keep swf files small they need to not use raster effects which is almost all the Effects, but as mentioned above there are some that are way cool, like Audio Spectrum as a Stroke substitute.
    Also, as in the tut by Lee you, can use AE Text to make very small swf’s and if you can use wingdings to get custom shapes to animate you can do a lot. Otherwise it’s AI files, solids and Masks.
  • Simka Cvetkovic
    May 14, 2008 at 5:00 pm
    Thank you very much!!!
