Activity Forums Apple Final Cut Pro Legacy After effects Titles Interlaced in Final Cut
  • After effects Titles Interlaced in Final Cut
    Posted by Jason Roberts on June 24, 2009 at 7:33 pm
    I have been having issues when importing a text video file exported from After Effects into Final cut.
    I’ve tried different Codecs, different Frame Rates and a few other ways but they have all rendered the same results.
    A lot of the text is rather thin. But even the thicker portions are having the problem(Especially rounded characters)
    My sequence setting are 720×486, NTSC D1 10-bit Uncompressed.
    Steve Oakley replied 17 years, 2 months ago 3 Members · 2 Replies
  • Walter Biscardi
    June 24, 2009 at 8:27 pm
    [Jason Roberts] “My sequence setting are 720×486, NTSC D1 10-bit Uncompressed. “
    NTSC SD is interlaced. Lower field first. Those are the exact render settings you should be using in AE. 720×486 Lower Field First.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Steve Oakley
    June 25, 2009 at 1:22 am
    well I do progressive NTSC all the time. just let the video card interlace on the way out… that said
    in FCP, select the clip, hit command 9 for clip info. there is a field you can right click to change how FCP is dealing with the clip – upper, lower or progressive.
    I’d also check your TL settings. sometimes FCP autmagically gets mixed formats right, other times not. in this case you may need to change the clip interpetation so FCP does the right thing.
