Activity Forums Adobe After Effects After effects Scripting; how deep does the rabbit hole go?
  • After effects Scripting; how deep does the rabbit hole go?
    Posted by Joseph Kitchin on January 19, 2013 at 9:30 am
    i actually posted on here a while back about this same project, but haven’t touched it in forever. I determined that after effects was probably my best bet for making this project work
    My goal is to use after effects scripting to make a series of quick-access tools SPECIFICALLY for this project, compressing several steps that must be constantly repeated into a few drags and a drop down box.
    here is the ultimate goal, to make a toolset to mass-produce these
    https://www.youtube.com/watch?v=-Z1mEqxEaZQ&list=PL8EAB26A0EA5CF16E
    for this is basically need to do one very important thing, with some stuff bundled into that. are any of these possible with Expressions? where should i start?
    -> i need some way to define a text box, position it, then choose from a series of stock text animations from a drop-down box, as well as if it’s per-word or per-letter, and the animation speed. The generated text box must have handles on the timeline for fade-in and fade-out, which are independent of the animation speed (so the text can fade in and animate, then hang around until the scene changes).
    it is very important that the process be this quick, as i’ll need to make lots of pages like this and not having to take ten minutes per page would be great.
    the visual effects and audio are separate things entirely, and probably not nearly as complex
    Joseph Kitchin replied 13 years, 8 months ago 2 Members · 2 Replies
  • Diego Mellado
    January 19, 2013 at 9:31 pm
    Hi!
    I use expression quite hard, and if you want to make a kind of toolbox, I guess you should think of scripting better than using expresions.
    May be somebody can give you a better advice, but I would start looking into scripting.
    Best,
    Diego
  • Joseph Kitchin
    January 20, 2013 at 12:13 am
    oh, i was under the impression that scripting in after effects was referred to as expressions (to make after effects seem more unique or something, marketing stuff), didn’t realize they were distinct things
