Activity › Forums › Adobe After Effects › After Effects – Rounded Rectangle
Posted by David Mac on May 26, 2018 at 12:31 pmHi guys.
I have some questions about making rounded lower third.1. I want make lower third like this gif image :
https://images.creativecow.net/u/327877/comp.gif
I tried different ways but I did not get any results. as you know when you want animate rounded rectangle, the rounded get distort
2. After animate From right point , i want scale it from left point to right for make circle like before.
thanks ❤
Roei Tzoref replied 8 years, 4 months ago 4 Members · 8 Replies -
Kalleheikki Kannisto
May 26, 2018 at 4:17 pmIf you use a shape layer, use the Rectangle Path properties rather than the Transform properties. Set the roundness to 100, unlink the x width and height and adjust width. To keep left edge in place adjust position x coordinate by adding half of the width.
Senior Graphic Designer -
Roei Tzoref
May 26, 2018 at 4:55 pmto elaborate on what K Suggested, use an expressing by linking the size to the position and add “/2” like this:
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com -
David Mac
May 26, 2018 at 5:51 pmThanks guys. it work.
1. and now , how to trim it for transorm it to circle like Trim Path? start to end
2. and how to resize it from Right to left ? -
Roei Tzoref
May 26, 2018 at 6:18 pm[David Mac] “and now , how to trim it for transorm it to circle like Trim Path? start to end”
not sure exactly what you mean. trim path works best for stroke and not a fill. so you can leave the stroke color and add a trim path and see if that’s what you want
[David Mac] “2. and how to resize it from Right to left ?”
/-2Roei Tzoref
David Mac
May 26, 2018 at 7:18 pm -
Roei Tzoref
May 26, 2018 at 7:39 pmoh James Bond. why didn’t you say so?
actually the most efficient way is probably using trim path and a stroke.
create a path with the pen tool, use stroke and round caps and set animation for:
end 0.1% (keyframe) until 100% (keyframe) – that will be the stroke drawing.
then set animation to the start parameter – 0% (keyframe) to 99.9% (keyframe)
you could also pull this off with several other ways, but this to me looks like the easiest way.
Roei Tzoref
Steve Bentley
May 26, 2018 at 11:58 pmActually that’s Touchstone’s logo. James Bond was just a wandering dot
Roei Tzoref
May 27, 2018 at 6:13 amI see. I think there was a movie company with something like that “orion”
Roei Tzoref
